Sybex7254
Aug 26, 2015Aspirant
Initializing HD's taking FOREVER!
I have a ReadyNAS NV+ (RND4410) that I got from a friend who had been using it with 4 x 1TB drives. I want to use it with 4 x 2.0 TB drives and cannot get even one drive to initiate. I have Erased ...
- Aug 27, 2015
Maybe try powering down your other NAS, removing the drives (label them by slot) and then insert one of the unformatted new drives. After that finishes, try moving it to the problematic NAS (powered down) and see if it boots.
Do you have the original 1 TB drives?
Sybex7254
No firmware is displayed but I believe it is 4.1.14. Currently I have a single 1.5 TB harddrive in there just trying to get it to initialize.
The Erase process did not take more than a few seconds and the NAS reboots. If the drives are locked as you say, can this be reversed?
Aug 26, 2015Guru - Experienced User
Netgear can reverse it (and generally netgear folks here will do it as a courtesy). If the drive is locked, you won't be able to quick-format it in a PC either.
