robertolo's avatar
robertolo
Install RAIDar on Mac OS Catalina
Hi,
I am trying to recover an old Readynas. But prior to that, I need to install Raidar as you know already (on a Mac OS 10.15.7 Catalina).
So I am downloading the installer dmg from https://kb.netgear.com/20684/ReadyNAS-Downloads . It turns out that I need to install OpenJDK or any JRE in general, from v7. Here comes the problem. I already have a JRE installed!
⋊> ~ java -version
openjdk version "16" 2021-03-16
OpenJDK Runtime Environment AdoptOpenJDK (build 16+36)
Eclipse OpenJ9 VM AdoptOpenJDK (build openj9-0.25.0, JRE 16 Mac OS X amd64-64-Bit Compressed References 20210311_66 (JIT enabled, AOT enabled)
OpenJ9   - 022d65424
OMR      - 09514431e
JCL      - 0c11227a21a based on jdk-16+36)
⋊> ~ echo $JAVA_HOME
/Users/robertolo/.sdkman/candidates/java/16.0.0.j9-adpt
I have tried other java versions + providers, but it does not change anything. Could you please help me? Thanks.
  • StephenB's avatar
    Why?  I'm not seeing what that will accomplish for you.
    • robertolo's avatar
      robertolo
      Well, I just thought that it would be necessary for the initial set up. I will check later today.
      By the way, I've tried the same on other not Mac machine and I cannot get rid of that validation error. Does raidar even work at all?
      • rn_enthusiast's avatar
        rn_enthusiast
        Virtuoso
        Yea RAIDar is not mandatory and I will be dammed if I ever install Java just for this application :)
ProSupport for Business
