Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
TeknoJnky
Dec 13, 2012Hero
you can just do a factory default, either from the web admin or the boot menu, leave the disks in the device and it will create the x-raid and start resyncing.
you should get approx 3.8tb or so, the extra 1tb on the 3tb drive ill go unused until you get a second 3tb drive.
once you add a second 3tb drive, it will expand both layers giving you about 6.3tb total
