Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
Costikos
Dec 14, 2012Aspirant
StephenB wrote: It all happens automatically. XRAID-2 is giving you single-redundancy - so all your data remains available if one of the drives fails. When you replace a disk, you temporarily lose the redundancy, but your data is all there. The NAS re-establishes the redundancy first (through the resync) and then expands the volume to use the extra space.
Costikos wrote: ...but what happens with the data on that 2TB? will i have to manually transfer them from the 2TB to another disk and then transfer them back to the new 3TB? or will the system do it on its own? if this happens, will i have to do anything administrative wise? or will it all happen automatically with the removal of the 2TB and the insertion of the 3TB?
Note that you should still have a backup though, especially when you are working with the disks. If a drive problem is uncovered during the process above, you usually end up losing all the data, not just some of it. RAID is an all-or-nothing kind of thing. And putting your data exclusively on one device is not a good idea.
In order to have a backup of all the data, does that mean that i have to have another nas to do it? Or can my current nas back it up somehow?
