Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
Costikos
Dec 15, 2012Aspirant
excellent. thank you!
one last question. should i install the 3TB disk, second in order to serve as the redundant disk, or should i insert another 2TB disk as second and then the 3tb disk?
i am asking this because in the future i will certainly install more disks of higher capacity.
