Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
TeknoJnky
Dec 15, 2012Hero
you should add the 2nd 2tb first, then the 3tb.
or as I mentioned earlier, just default with all disks in place and x-raid will figure it out.
