Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
Dec 16, 2012Guru - Experienced User
If you are going to do a factory default, put in all your disks first and then do it.
