Costikos
Dec 13, 2012Aspirant
Installing a lower capacity disk than the ones running
Hi, i have just bought the nv+ v2 and i tried to install a hard disk. i already had two compatible hard disk, which have a capacity of 2TB each and i also bought another one which has a capacity of...
Costikos
Dec 16, 2012Aspirant
ok, thanks! two last questions (hopefully)
1. how exactly do i do the factory default? (by the reset button on the back of the nas?)
2. i am trying to copy data from the disk that is in the nas to a disk that is connected on the nas via usb 3. the procedure/method that i am using is to open the explorer on my computer, then find nas and then drag and drop the folder from the nas to the external usb disk connected to the nas. the procedure takes a lotof time and i think it does it because by this method (i am under the impresion) that the data goes through the pc firs. is there a faster way?
