arpanj2's avatar
arpanj2
Tutor
Nov 13, 2014
Installing and running OpenVPN @ boot - PrivateInternetAcces
Hi All,
I have been trying to install OpenVPN and use PrivateInternetAccess (PIA) as my VPN Server on my ReadyNAS for a while now - my prime usecase was that I wanted all the connection to be encrypted while exposing it to external world (like sharing files right out of my NAS or torrent). The following are the steps which worked for me and my NAS is always on VPN now.
1. Enable SSH by going into System -> Settings in your WebView
PS: This may cause problem with Netgear support - so do @ your own risk. However, I am not modifying anything with system and it looks safe to me.
2. Download Putty from link below
http://the.earth.li/~sgtatham/putty/0.63/x86/putty.exe
3. Go to command prompt, navigate to the directory where you placed putty. Once in the directory, execute the following command
putty <NAS Address>
4. You will see a terminal window open up asking for your login. enter your login info that you use to access your NAS from webbrowser
5. Now enter the following command on the terminal prompt
apt-get install openvpn
6. This will install OpenVPN. Now, you need to get the VPN config files from PIA. Use the following commands below to navigate the OpenVPN directory and get the files
cd /etc/openvpn
wget https://www.privateinternetaccess.com/openvpn/openvpn.zip
7. Extract the files using unzip command. If you dont have the program, use apt-get command as above (replace openvpn with unzip)
unzip openvpn.zip
8. Now, create a file - say userpass.file and type username on first line and password on the second line and save it. To save a file, press Esc and type :wq (including the colon) and press enter
vi userpass.file
9. Chose one of the .ovpn file - for this eg, I chose France.ovpn and edit it. When you open it using the vi command, there will be a line auth-user-pass. Change it to auth-user-pass userpass.file and save the file as mentioned above.
vi France.ovpn
10. at this time, you are all set to create a VPN connection. However, the issue is that now you need to always activate it manually. So, now we will create a startup file which runs automatically everytime you boot your NAS. Use the following commands to create a new file called startvpn.sh - you can name whatever you want
cd /etc/init.d
vi startvpn.sh
11. Now type the following lines and save the file
#!/bin/bash
cd /etc/openvpn
openvpn France.ovpn
12. Once saved, you need to make the script executable. Use the command below for the same
chmod +x startvpn.sh
13. Now, you need to add this script to run at everyboot. To do so, you need to add the following command in crontab file. Open the crontab file using command
crontab -e
and then add the following line anywhere in the file
@reboot ./etc/init.d/startvpn.sh &
. Save it using the Esc -> :wq!
13a. You can also use the following command to add this command to startup
update-rc.d startvpn.sh defaults
14. Now you need to see if the VPN has started. To do so, type ifconfig on the command line and you will see a new connection starting with a config similar to below
tun0-00 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
This means your vpn is running perfectly and you added another layer of security.
Please let me know if this worked for you - i am not a Linux expert but will try to answer any questions you may have
Linux experts - comment/add anything to make it better.
Thanks,
Arpan
  • Thanks to arpanj2 for starting the thread. I've found there are better and easier ways to do a few things which may have saved people some frustration. I hope this helps! If anyone wants to merge my suggestions with the original to create a definitive post, they're most welcome. Here are my changes:
    Step 5: It's probably a good idea to retrieve new lists of packages so that you fetch the latest version of openvpn:
    # apt-get update
    ... # apt-get install openvpn
    If you want an easier to use text editor, now is a good time to install nano:
    # apt-get install nano
    Step 8: If you installed nano, you probably want to use it:
    # nano userpass.file
    Step 9 is where I depart a bit; I prefer to keep the unzipped PIA .ovpn files unmodified. Instead, I create a copy of my preferred PIA site then edit it as directed:
    # cp France.ovpn My.ovpn
    Or, if you like one-liners:
    # sed s/"auth-user-pass"/"auth-user-pass userpass.file"/ France.ovpn > My.ovpn
    Steps 10 through 13a: There is no need to create a script or a cron job!!!
    New Step 10: Let's now test our config file by running OpenVPN in the background:
    # openvpn My.ovpn &
    You'll see console output which looks something like this:
    [1] 6938
    root@hostname:/etc/openvpn# Sun Nov 1 01:26:49 2015 OpenVPN 2.2.1 arm-linux-gnueabi [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec 1 2014
    Sun Nov 1 01:26:49 2015 WARNING: file 'userpass.file' is group or others accessible
    Sun Nov 1 01:26:49 2015 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
    Sun Nov 1 01:26:49 2015 LZO compression initialized
    Sun Nov 1 01:26:49 2015 RESOLVE: NOTE: france.privateinternetaccess.com resolves to 13 addresses
    Sun Nov 1 01:26:49 2015 UDPv4 link local: [undef]
    Sun Nov 1 01:26:49 2015 UDPv4 link remote: [AF_INET]108.61.122.156:1194
    Sun Nov 1 01:26:49 2015 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
    Sun Nov 1 01:26:51 2015 [Private_Internet_Access] Peer Connection Initiated with [AF_INET]108.61.122.156:1194
    Sun Nov 1 01:26:53 2015 TUN/TAP device tun0 opened
    Sun Nov 1 01:26:53 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
    Sun Nov 1 01:26:53 2015 Initialization Sequence Completed
    It might look as though you don't have a prompt, but you do. Just hit enter a to get a fresh one.
    New Step 11: Check the vpn is running with ifconfig:
    # ifconfig
    ...and do whatever testing you need with your applications.
    New Step 12: Find the job you created earlier and send it a TERM signal with the kill command:
    root@hostname:/etc/openvpn# jobs
    [1]+  Running                 openvpn My.ovpn &
    root@hostname:/etc/openvpn# kill -term %1
    Sun Nov  1 02:23:54 2015 event_wait : Interrupted system call (code=4)
    root@hostname:/etc/openvpn# Sun Nov  1 02:23:54 2015 /sbin/ifconfig tun0 0.0.0.0
    Sun Nov  1 02:23:54 2015 SIGTERM[hard,] received, process exiting
    [1]+  Done                    openvpn My.ovpn
    New Step 13: Once you're happy with your configuration file, rename it to something ending in '.conf':
    # mv My.ovpn client.conf
    New Step 14: Start the OpenVPN init script:
    # /etc/init.d/openvpn start
    [ ok ] Starting openvpn (via systemctl): openvpn.service.
    That's it, you're done! As installed by default on my RN104, the OpenVPN init script looks for .conf files in the default /etc/openvpn directory where we unzipped the PIA files and did everything else. The OpenVPN init script is also set by default to start with the other services at runlevels 2-5. This means the init script will start a connection using your .conf file when the system reboots.
    If you're like me, and prefer to access your ReadyNAS from the outside world using port forwarding configured on a router, you'll notice that turning on OpenVPN breaks remote access. I'll write another reply soon with directions on how to configure IP rules and routes on your ReadyNAS so that your port forwarding setup will function properly.
    Until then, TTFN!
ProSupport for Business
