kraeks
May 30, 2012Aspirant
Installing PHP5 on Readynas Duo v2 (should work on all ARM)
Since i'm not a big fan for paying for things that are easily done by myself, I thought i'd take the time to write down how i went about to install and configure PHP5, MySQL and phpMyAdmin on the Re...
- Jun 30, 2014
For the beginners like me, you can just buy https://rnxtras.com/addons/php-5-4-readynas-5-arm
Worked perfectly well on ma RND2000 ARM 5.3.10
:D
kraeks
Now we're going to install MySQL and phpMyAdmin
2. Installing and configuring MySQL
This is a pretty straight forward process. Start by installing the package with apt-get:
Then proceed into the MySQL console by typing:
Now create a user (or as many as you need) with this command:
When you've created all the users you need, proceed with the following:
Write down your freshly created password and store it in a secure location.
For example in a file in /root. A note in your drawer isn't a very good option.
You don't have to create a database at this point since this will be very easily done from phpMyAdmin.
2. Installing and configuring phpMyAdmin
Go to your www-root and download the latest phpMyAdmin version with wget using the URL found here:
In this example we will be using tar.gz.
Extract the file using the following command:
Now change the name of phpMyAdmin into something a little easier to write, for example phpadm by typing the following:
Now you should be able to access phpMyAdmin from your external url followed by /phpadm.
Use the username and password created in MySQL to log in.
sudo apt-get install mysql-server
sudo mysql
CREATE USER '<username>'@'localhost' IDENTIFIED BY '<42-digit password>';
FLUSH PRIVILEGES;
exit
http://www.phpmyadmin.net/home_page/downloads.php
sudo tar xvzf <filename>
sudo mv <dirname> phpadm
