RSherman90
Apr 18, 2020Apprentice
Is a NAS vulnerable to Ransomware attack?
We have a small workgroup network of 10 PCs and an RN-424 serving shared data to all the PCs. All the PCs do image backups to a Share on the NAS as well as local image backups to s 2nd harddrive on e...
ReadyNASinUK
Apr 20, 2020Aspirant
If you are new to NAS, you should probably research how btrfs snapshots work generally. They also provide some ability to roll back to older file versions in response to user errors.
No, not new to ReadyNAS but not an expert (yet..)
Regarding the use of snapshots...
We used to use snapshots, but found it made searching on the user shares very lengthy, and the results confusing as Windows would find all the versions of a given file.
Also just wondering... presumably the snapshot function would create a "delta" roughly equal to the size of the original file if malware tried to encrypt it. Unless a lot of space is reserved, what would happen if the drive ran out of space while malware was attempting to encrypt the contents: would the malware be brought to a halt (hopefully) or would btrfs give up on the snapshot totally, (hopefully not) or start deleting older snapshots (sounds plausible, at least for auto-created).
Are you aware of any studies carried out on this? Or are the answers obvious?
Meanwhile I am trying to work out a way to block users accessing files on other PC's, but let the ReadyNAS access the files for backup.
Apr 20, 2020Guru - Experienced User
Yes. All writes to the original file result in new blocks being allocated to the main copy, and the older block is retained in any snapshots. That includes malware encryption of the files.
The NAS will start deleting the snapshots automatically when the volume gets too full (~90%). There is a threshold for that you could set in the Admin Web UI.
As I suggested earlier, you'd want to keep the volume no more than 40% full if you want to use this strategy. Then if the malware rewrites every file, the space usage would double to 80%. Then there would still be 20% margin.
There is no study on this that I know of, but malware could defeat this approach simply by encrypting each file a second time. I guess there could be some malware that does this.
I don't allow the NAS to make the files visible in the share. I do enable show previous versions in Windows though.
- RSherman90Apr 23, 2020Apprentice
Our first step, based on all the great information offered in this thread, is to expand the NAS storage from 4 x 3TB, XRaid, to 3 x 8TB, XRaid with 1 x 8TB Global Spare. We'll be putting the 4 x 3TB disks into our RN104 and setting up the RN424 with the new disks. Should have the data transferred to the RN424 over the weekend.
1. I find little info on setting up a Global Spare and how it would be used in practice to either replace a failing(ed) disk or to expand the capacity of the NAS at a later time. Can anyone elucidate? In the past, we've always just kept an extra disk on hand for any emergency failure and upgraded the entire array to increase capacity as needed. I'm thinking the Golbal Spare is a better route. Yes?
2. Our second effort will be to backup the local PC image backups to a non accessible share on a NTSF USB enclosure attached to the NAS. This should be safe from a Ransomware attack. The drive will also be easy to move to a local PC in order to restore an image. BTW - we use Macrium Reflect to create the PC images per defined schedules.
Any flaws in our thinking? Thanks.
- SandsharkApr 23, 2020Sensei
If the time period between failure and drive replacemnt could be long, then a global spare can be useful, since it will become the replacement immediatly upon failure.
If you are l;ikely to be able to manually swap the drive quickly after a fialure, there are a couple dis-advantages of using a global spare. First is that the dirve will accumulate hours toward eventual failure. manybe not as badly as one constantly moving the hears for ereads & writes, but wera nontheless. The other id that the sync of the spare will occur before you have a chance to make sure your other drives look healthy and the backup is in order in case another fails.
I've never added a global spare to expand an array, so can't help you there.
- StephenBApr 23, 2020Guru - Experienced User
I don't use them either.
If you generally have access to the site, I think you are better off with a spare that isn't inserted into the NAS. But right now, a global spare could be good thing.
