AQuatro
Mar 13, 2022Aspirant
Is RN102 this same as RN10200?
Is RN102 this same as RN10200 ? Is posibble to take disk from RN102 and insert to RN10200? Will be working without loss data?
Mar 13, 2022Guru - Experienced User
Yes.
AQuatro wrote:Is possible to take disk from RN102 and insert to RN10200?
You can directly migrate disks from the RN102 to any OS-6 platform (including the x86 platforms like the RN422).
AQuatro
Ok. It's good info for me.
I'll buy second one.
- SandsharkMar 14, 2022Sensei
Given the severe memory limitation of the 100 series, I suggest you look for at least a 200 series, which will also accept your volume with no issue (as will any OS6 NAS). But best of luck finding one at a reasonable price.
