BotanyBay
Sep 17, 2017Tutor
Is the EDA500 discontinued?
Looking online to purchase an EDA500 expansion chassis and it appears that it is a "discontinued item". Is this model being replaced by something different?
mdgm-ntgr
Sep 18, 2017NETGEAR Employee Retired
Getting an additional ReadyNAS and hooking that up to your network provides much better performance and better value imo than getting an EDA500.
- BotanyBaySep 18, 2017Tutor
I understand that, I am looking to use the unit for a specific purpose of moving data between two locations and thought that the unit might be ideal.
I am just looking for confirmation if it is no longer being manufactured?
- SandsharkSep 20, 2017Sensei
BotanyBay wrote:I understand that, I am looking to use the unit for a specific purpose of moving data between two locations and thought that the unit might be ideal.
It's not designed with that in mind. You would be better off with a USB3 based device. If you need more space than a single drive can handle, I have successfully used another manfacturers USB RAID device with a ReadyNAS.
Amazon had a fire sale on the EDA500 a few months ago, which did make me suspect that it was being discontinued.
If you really want one, there are a couple for sale on eBay.
- BotanyBaySep 22, 2017Tutor
Yes and no, the issue with a USB3 based device is that I can't use BTRFS and thus cannot use ReadyDR to that volume. The EDA500 volume does support having a volume which is BTRFS and thus could be the target for a ReadyDR share.
The ideal solution would be the ability to target a local USB3 drive as BTRFS and be able to send ReadyDR shares to that volume. At the moment that is not an option.
I am working through disaster recovery options and there are a couple of holes which I am trying to plug ***Grin***
