BotanyBay
Sep 17, 2017Tutor
Is the EDA500 discontinued?
Looking online to purchase an EDA500 expansion chassis and it appears that it is a "discontinued item". Is this model being replaced by something different?
mdgm-ntgr
Sep 18, 2017NETGEAR Employee Retired
Getting an additional ReadyNAS and hooking that up to your network provides much better performance and better value imo than getting an EDA500.
BotanyBay
Sep 18, 2017Tutor
I understand that, I am looking to use the unit for a specific purpose of moving data between two locations and thought that the unit might be ideal.
I am just looking for confirmation if it is no longer being manufactured?
- SandsharkSep 20, 2017Sensei
BotanyBay wrote:I understand that, I am looking to use the unit for a specific purpose of moving data between two locations and thought that the unit might be ideal.
It's not designed with that in mind. You would be better off with a USB3 based device. If you need more space than a single drive can handle, I have successfully used another manfacturers USB RAID device with a ReadyNAS.
Amazon had a fire sale on the EDA500 a few months ago, which did make me suspect that it was being discontinued.
If you really want one, there are a couple for sale on eBay.
- BotanyBaySep 22, 2017Tutor
Yes and no, the issue with a USB3 based device is that I can't use BTRFS and thus cannot use ReadyDR to that volume. The EDA500 volume does support having a volume which is BTRFS and thus could be the target for a ReadyDR share.
The ideal solution would be the ability to target a local USB3 drive as BTRFS and be able to send ReadyDR shares to that volume. At the moment that is not an option.
I am working through disaster recovery options and there are a couple of holes which I am trying to plug ***Grin***
- StephenBSep 23, 2017Guru - Experienced User
BTRFS is a supported format for USB drives. But I'm not sure if ReadyDR supports external drives.
