wiland's avatar
wiland
Is there a UPS compatibility list?
Is there a UPS compatibility list similar to the hard drive compatibility list or do you just have to sift through the forums and find out what units have worked and haven't worked?
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    There used to be one, however there's so many units out there it's impossible to test them all.
    A few requirements:
    1. Must have USB port (Serial-to-usb cable will not work).
    2. Compatible with NUT (Network UPS Tools)
    Most APC units which have a USB port are compatible with the ReadyNAS.
ProSupport for Business
