ChristhianIT007
May 04, 2016Follower
Issue with Disk not working with ReadyNAS device.
Model: ReadyNAS 2100 v2 [X-RAID2]
Hi There,
I would like to get some help with an issue we're facing with a Netgear ReadyNas device. There was a disk that suddenly went death and we pu...
May 04, 2016Guru - Experienced User
ChristhianIT007 wrote:
We want to know if this could possibly be due to that slot that it's not working since we have a third disk which is the exact same model and it's working fine.
This is certainly possible, but I'd have to add it is unlikely.
If you can, power down the NAS and remove disk 1. Then test it in a Windows PC with vendor tools (Seatools for seagate, Lifeguard for Western Digital, ...) Also take a look at the SMART stats (if the PC can recognize the drive).
Note that Windows doesn't support the file system, so it won't mount that. But you should see the disk show up in Windows Disk Manager.
