Smiley4187
Mar 24, 2018Follower
Largest HD Size on ReadyNAS Duo V2
I have got a Duo V2 with what the Firmware check says is the latest firmware, Raidator 5.3.13, The two TB drives in it are getting smaller everyday. What is the largest HDs I can put in as a re...
JohnCM_S
Mar 24, 2018NETGEAR Employee Retired
Hi Smiley4187,
Welcome to the Community!
You may also check the Hard Disk Compatibility List for reference for the highest drive capacity that it can support. Note: The HCL might not be updated for the Duo V2 since it is already EOL.
JohnCM_S
NETGEAR Community Team
Sandshark
Mar 24, 2018Sensei
I'm not sure where you are getting that information. JohnCM_S, but I would expect a Netgear moderator to have his facts straight. The DuoV2 absolutely can support drives >4TB. I put 6TB's in one and it worked just fine. The original documentation only lists 4TB because nothing bigger existed at the time. There may be a limit in the firmware of the volume size, but I know it's at least 12TB. If there is a real hard limit, please get your facts straight and post it.
Now, with the slow processor and small memory of the DuoV2, there is perhaps a practical limit, especially with multiple users. But used by a single user where speed is not critical (like as a backup device for a computer a newer NAS), a bigger volume certainly is a viable option.
As far as the hardware compatibility list goes, it is woefully out of date. It even lists drives like the WD Caviar Green and Seagate Baracude DM and DL drives that are very poor choices for a NAS (at least when part of a RAID array)..
