krit
Mar 11, 2014Follower
LDAP support?
Can LDAP be used for user authentication and groups?
GGITech
Jul 12, 2015Apprentice
LDAP App support has been pulled.....so good luck.
Downgrade to 6.2.2 (with known issues)
Install LDAP App
Upgrade to current
- JUST DO NOT REMOVE AN APP WHILE ON 6.2.2 or you will hose out the NAS Admin Interface.
Install LDAP App
Upgrade to current
