Dewdman42
Apr 18, 2023Virtuoso
Leave ReadyNAS, possible replacements?
Given that Netgear appears to be abandoning this product line, and given that even WhoCares is giving up on it, I am going to consider alternative solutions to replace my aging 524X. I hope to hear...
eton
Apr 20, 2023Luminary
According to mdgm every ReadyNAS has a serial console port. So if your device doesn’t have HDMI, you will need to figure out how to connect to the serial interface.
Apr 21, 2023Guru - Experienced User
I think you are assuming that the ReadyNAS allows the bios to be configured through the serial port.
