Dewdman42
Apr 18, 2023Virtuoso
Leave ReadyNAS, possible replacements?
Given that Netgear appears to be abandoning this product line, and given that even WhoCares is giving up on it, I am going to consider alternative solutions to replace my aging 524X. I hope to hear...
tony359
Jul 12, 2023Apprentice
Hi,
I'd like to test an alternative OS following some severe issues my Pro6 is having with OS6. Likely a HW fault but I want to explore the "OS bug" path.
My NAS has an intel 6600 and 8GB of RAM. I only use the NAS as file storage. I also run iDrive and I see it's not available for anything but the main brands. It's available for linux though? But I can find an alternative, that's not a deal breaker.
I am thinking of openmediavault - I looked into TrueNAS and it's got silly HW requirements.
Would anybody recommend anything else for my NAS? Would openmediavault support RAID expansion so I don't have to reset my whole RAID if and when I add or upgrade a drive?
Any indication on how to install using the internal USB storage? I can use an external one but if I could re-use the internal one, that would be great.
I do have VGA output if necessary.
Thank you!
Sandshark
Jul 12, 2023Sensei
I think OpenMediaVault is a good choice. That it's also Debian based gives you a leg up on the learning curve. I think it also supports BTRFS (it's been a while since I looked at it). I'll likely switch to it if I abandon ReadyNAS OS. Doing the switch on our existing hardware is a lot easier for those of us with ReadyNAS that have, or can have installed, a monitor port.
- tony359Jul 12, 2023Apprentice
Thank you. I ordered a small but fast (given it's USB 2.0!) USB stick to use as a boot device.
I'll install, test and report back 🙂
Do you think iDrive - which has a Linux version available - could be installed?
