miogpsrocks
Jan 26, 2019Tutor
legacy readynas Pro on OS6. How to Upgrade from 2TB to 8TB
So I just upgraded to the OS6 firmware( Firmware 6.9.5 to be exact)
I have 2TB hard drive and want 8TB hard drive.
Can I just replease the entire array or do I have to replace 1 drive a...
miogpsrocks
Jan 26, 2019Tutor
In other words, I want to upgrade from 6 X 2TB hard drives to 6 X 8TB hard drives.
- TeknoJnkyJan 26, 2019Hero
if there is no data, then just power down, pull all the old drives, put all the new drives in, and power back up.
new system will be initiallized and raid 5/x-raid will start resyncing.
if you want raid 6/dual redundancy, then you must delete the default volume, create a new raid 6 volume, then re-enable x-raid (if desired).
- StephenBJan 27, 2019Guru - Experienced User
This is the fastest and best approach. Replacing one drive at a time in the existing array will take a lot longer.
- miogpsrocksJan 27, 2019Tutor
Ok, I will do this.
Just as a side note, which drive/bay is #1? like the bottom left, top left, etc.l..
I am trying to find a layout diagram of which bay 1, bay 2, bay 3, bay 4, bay 5, bay 6.
I have always heard its a good idea to number each drive in case of a problem.
Thanks.
- Sep 05, 2015Retired_Member
