miogpsrocks
Jan 26, 2019Tutor
legacy readynas Pro on OS6. How to Upgrade from 2TB to 8TB
So I just upgraded to the OS6 firmware( Firmware 6.9.5 to be exact)
I have 2TB hard drive and want 8TB hard drive.
Can I just replease the entire array or do I have to replace 1 drive a...
TeknoJnky
Jan 26, 2019Hero
if there is no data, then just power down, pull all the old drives, put all the new drives in, and power back up.
new system will be initiallized and raid 5/x-raid will start resyncing.
if you want raid 6/dual redundancy, then you must delete the default volume, create a new raid 6 volume, then re-enable x-raid (if desired).
- Sep 05, 2015Retired_Member
