F_L_
May 10, 2013Tutor
LMS for OS6
A LMS (Logitech Media Server) add-on for OS6 would be great.
I am thinking about upgrading to the new OS but need LMS (even if its obsolete).
Anyone got it running from source?
- kervernAspirantyes my squeezebox love and dream it !
- super_poussinVirtuosowill be in my dropbox in a few minutes enjoy and thanks to Govnah
- vandermerweMasterThat sounds great super-poussin, how do we get it?
I don't have an OS6 machine yet, but this is the only reason I'm not getting one. - vandermerweMaster
- GovnahAspirant
vandermerwe wrote: https://www.dropbox.com/sh/ie9pwk1wut72ias/-puRHmcmD2/Logitech%20Media%20server
Oh I see.
How is it installed?
See the readme in the directory. You can install via frontview from the apps tab and see the upload icon top right. Or if you are comfortable with SSH and Linux you can do it from the CLI. - vandermerweMasterThanks. I'll consider the purchase now.
How would plugins work with this version, as normal? - mhergerAspirantGovnah - is the lms deb file a custom build? If so, what did you modify? Maybe we can handle this in a simpler way, so users don't depend on you providing builds.
- super_poussinVirtuosothe lms deb file is the interface for frontview so after installing lms and the logitec deb , you can upgrade the logitech deb without need to insall lms deb file again
Ps : done by me :P - mhergerAspirantNice - thanks!
What LMS versions are supported by your add-in? - super_poussinVirtuosoThe one in the Dropbox and upper and perhaps lower version . It will work if Logitech did not rename their startup script
