F_L_
May 10, 2013Tutor
LMS for OS6
A LMS (Logitech Media Server) add-on for OS6 would be great. I am thinking about upgrading to the new OS but need LMS (even if its obsolete). Anyone got it running from source?
jukkaforss
Jul 07, 2013Tutor
jukkaforss wrote: Now I know what difference is between Radio and Trasnporter or Duet.
Radio can play Apple lossless native, but Transporter and Dut don't.
Duet transcode log:
[13-07-05 18:02:09.4103] Slim::Player::TranscodingHelper::checkBin (241) Found command: [faad] -q -w -f 1 $START$ $END$ $FILE$ | [sox] -q -t wav - -t flac -C 0 $RESAMPLE$ -
[13-07-05 18:02:09.4112] Slim::Player::TranscodingHelper::getConvertCommand2 (428) Matched: alc->flc via: [faad] -q -w -f 1 $START$ $END$ $FILE$ | [sox] -q -t wav - -t flac -C 0 $RESAMPLE$ -
[13-07-05 18:02:09.4122] Slim::Player::Song::open (408) Transcoder: streamMode=F, streamformat=flc
[13-07-05 18:02:09.4139] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (553) Using command for conversion: "/usr/share/squeezeboxserver/Bin/i386-linux/faad" -q -w -f 1 "/data/media/iTunes/Music/Black Sabbath/13 [Deluxe Edition]/2-03 Pariah.m4a" | "/usr/share/squeezeboxserver/Bin/i386-linux/sox" -q -t wav - -t flac -C 0 - & |
[13-07-05 18:02:09.4149] Slim::Player::Song::open (558) Tokenized command: "/usr/share/squeezeboxserver/Bin/i386-linux/faad" -q -w -f 1 "/data/media/iTunes/Music/Black Sabbath/13 [Deluxe Edition]/2-03 Pariah.m4a" | "/usr/share/squeezeboxserver/Bin/i386-linux/sox" -q -t wav - -t flac -C 0 - & |
LMS tries to use i386 version of faad and sox located in /usr/share/squeezeboxserver/Bin/i386-linux/ -directory and ReadyNAS OS 6 can run only 64bit binaries.
If I install faad and sox and copy 64-bit binaries to /usr/share/squeezeboxserver/Bin/i386-linux/ -directory, it still don't work probably those LMS binaries are modified !!
Any idea how to get around this problem?
EDIT:
Found solution, those binaries need 3 libraries to work.
/lib/i386-linux-gnu/i686/cmov/libc.so.6
/lib/i386-linux-gnu/i686/cmov/libm.so.6
/lib/ld-linux.so.2
I copied those from my test debian wheezy and now also Duet and Transporter can play Apple lossless music. :D
super-poussin would it be possible to those libraries to LMS installation package ?
