F_L_
May 10, 2013Tutor
LMS for OS6
A LMS (Logitech Media Server) add-on for OS6 would be great. I am thinking about upgrading to the new OS but need LMS (even if its obsolete). Anyone got it running from source?
vandermerwe
Jul 15, 2013Master
hi
i have had to remove all http: as would not let me post more than 10 urls
After this operation, 32.1 MB of additional disk space will be used.
Get:1 //mirrors.kernel.org/debian/ wheezy/main libclass-isa-perl all 0.36-3 [12.3 kB]
Get:2 //mirrors.kernel.org/debian/ wheezy/main perl-modules all 5.14.2-21 [3,443 kB]
Get:3 //mirrors.kernel.org/debian/ wheezy/main perl amd64 5.14.2-21 [4,425 kB]
Get:4 //mirrors.kernel.org/debian/ wheezy/main libswitch-perl all 2.16-2 [21.0 kB]
debconf: delaying package configuration, since apt-utils is not installed
Fetched 7,901 kB in 21s (374 kB/s)
Selecting previously unselected package libclass-isa-perl.
(Reading database ... 11969 files and directories currently installed.)
Unpacking libclass-isa-perl (from .../libclass-isa-perl_0.36-3_all.deb) ...
Selecting previously unselected package perl-modules.
Unpacking perl-modules (from .../perl-modules_5.14.2-21_all.deb) ...
START(/tmp/lms_1.0.4_all.deb): Sun Jul 14 15:20:34 WEST 2013
Hit //mirrors.kernel.org wheezy Release.gpg
Hit //mirrors.kernel.org wheezy/main amd64 Packages
Selecting previously unselected package perl.
Unpacking perl (from .../perl_5.14.2-21_amd64.deb) ...
Hit //apt.readynas.com 6.0.8 Release.gpg
Hit //apt.readynas.com 6.0.8/updates amd64 Packages
Hit //apt.readynas.com 6.0.8/apps amd64 Packages
Hit //apt.readynas.com 6.0.8/main amd64 Packages
DONE(1): Sun Jul 14 15:20:37 WEST 2013
spooler returns spool_status=1 outbuf=(null) errbuf=(null) is_localapp=1 name=lms_1.0.4_all.deb pkgname=lms
Selecting previously unselected package libswitch-perl.
Unpacking libswitch-perl (from .../libswitch-perl_2.16-2_all.deb) ...
Setting up libclass-isa-perl (0.36-3) ...
Setting up perl-modules (5.14.2-21) ...
Setting up perl (5.14.2-21) ...
update-alternatives: using /usr/bin/prename to provide /usr/bin/rename (rename) in auto mode
Setting up libswitch-perl (2.16-2) ...
pkg[2/3]= adduser
pkg[3/3]= libc6
Chking dependencies..
pkg[1/3]= perl >= 5.8.8
Depenency perl >= 5.8.8 met
pkg[2/3]= adduser
Depenency adduser met
pkg[3/3]= libc6
Depenency libc6 met
Conflicts: slimp3, slimserver, squeezeboxserver, squeezecenter
Replaces: slimp3, slimserver, squeezeboxserver, squeezecenter
Section: sound
Priority: optional
Description: Streaming Audio Server
Logitech Media Server is a cross-platform streaming media server that supports a wide range
of formats, including AAC, AIFF, FLAC, Ogg Vorbis, MP3, WAV, and WMA.
fv-dpkginstall.awk: success
Success install dependencies for /tmp/logitechmediaserver_7.8.0~1371193145_all.deb
Selecting previously unselected package logitechmediaserver.
(Reading database ... 13389 files and directories currently installed.)
Unpacking logitechmediaserver (from .../logitechmediaserver_7.8.0~1371193145_all.deb) ...
Setting up logitechmediaserver (7.8.0~1371193145) ...
Adding system user `squeezeboxserver' (UID 40) ...
Adding new user `squeezeboxserver' (UID 40) with group `guest' ...
Not creating home directory `/usr/share/squeezeboxserver'.
Making sure that Logitech Media Server is not running first: No process in pidfile '/var/run/logitechmediaserver.pid' found running; none killed.
Starting Logitech Media Server.
DONE(0): Sun Jul 14 15:21:06 WEST 2013
spooler returns spool_status=0 outbuf=(null) errbuf=(null) is_localapp=1 name=logitechmediaserver_7.8.0~1371193145_all.deb pkgname=logitechmediaserver
START(/tmp/logitechmediaserver_7.8.0~1371193145_all.deb): Sun Jul 14 15:21:29 WEST 2013
Reading package lists...
new debian package, version 2.0.
size 97602734 bytes: control archive=72014 bytes.
252 bytes, 7 lines conffiles
555 bytes, 13 lines control
260065 bytes, 2604 lines md5sums
2039 bytes, 71 lines * postinst #!/bin/sh
469 bytes, 25 lines * postrm #!/bin/sh
919 bytes, 41 lines * preinst #!/bin/sh
305 bytes, 11 lines * prerm #!/bin/sh
Package: logitechmediaserver
Version: 7.8.0~1371193145
Architecture: all
Maintainer: Logitech/Slim Devices <[email protected]>
Installed-Size: 242700
Depends: perl (>= 5.8.8), adduser, libc6
Found 3 dependants
pkg[2/3]= adduser
pkg[3/3]= libc6
pkg[2/3]= adduser
pkg[3/3]= libc6
Depenency libc6 met
Section: sound
Priority: optional
(Reading database ... 17505 files and directories currently installed.)
Preparing to replace logitechmediaserver 7.8.0~1371193145 (using .../logitechmediaserver_7.8.0~1371193145_all.deb) ...
Stopping Logitech Media Server.
START(/tmp/lms_1.0.4_all.deb): Sun Jul 14 15:21:38 WEST 2013
Unpacking replacement logitechmediaserver ...
DONE(1): Sun Jul 14 15:21:40 WEST 2013
Making sure that Logitech Media Server is not running first: start-stop-daemon: warning: failed to kill 7149: No such process
DONE(0): Sun Jul 14 15:22:24 WEST 2013
START(/tmp/C:\Users\Cliffliz\Desktop\lms_1.0.4_all.deb): Sun Jul 14 15:24:47 WEST 2013
Success install dependencies for /tmp/C:\Users\Cliffliz\Desktop\lms_1.0.4_all.deb
dpkg: error processing /tmp/C:UsersClifflizDesktoplms_1.0.4_all.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
DONE(4): Sun Jul 14 15:24:54 WEST 2013
spooler returns spool_status=4 outbuf=(null) errbuf=(null) is_localapp=1 name=C:\Users\Cliffliz\Desktop\lms_1.0.4_all.deb pkgname=dpkg-deb: error: failed to read archive `/tmp/C:UsersClifflizDesktoplms_1.0.4_all.deb': No such file or directory
START(/tmp/C:\Users\Cliffliz\Desktop\lms_1.0.4_all.deb): Sun Jul 14 15:26:31 WEST 2013
DONE(4): Sun Jul 14 15:26:38 WEST 2013
START(/tmp/C:\Users\Cliffliz\Desktop\lms_1.0.4_all.deb): Sun Jul 14 15:31:43 WEST 2013
DONE(4): Sun Jul 14 15:31:51 WEST 2013
root@backupnas:/var/log/readynasd#
pkg[2/3]= adduser
pkg[3/3]= libc6
pkg[2/3]= adduser
pkg[3/3]= libc6
Depenency libc6 met
Section: sound
Priority: optional
Architecture: all
Found 3 dependants
pkg[2/3]= adduser
pkg[3/3]= libc6
pkg[2/3]= adduser
pkg[3/3]= libc6
Depenency libc6 met
Section: sound
Priority: optional
