F_L_
May 10, 2013Tutor
LMS for OS6
A LMS (Logitech Media Server) add-on for OS6 would be great. I am thinking about upgrading to the new OS but need LMS (even if its obsolete). Anyone got it running from source?
jelockwood1
Jul 18, 2013Guide
Thanks to super-poussin for producing an LMS installer for OS^, and thanks to vandermerwe to resolving the Apple Lossless issue (although I have a Squeezebox Radio and so would not have been affected).
I would like to suggest to super-poussin that a note be put somewhere in the text of the entry in the genie appstore to indicate which version of LMS is being used. I believe at the moment it will be 7.8 but it will be useful to know what version it is when one goes and gets any future updates.
For those like me who have multiple LMS servers if you have mixed versions it causes your Squeezebox to reload the different versions firmware. If they are the same version you avoid this unpleasantness.
Also am I right in believing that 7.7.2 was the last official version of LMS, and that 7.8 is still in beta and is a 'community' update of LMS since Logitech have discontinued their own development of it?
