Orange_GT3
Jun 25, 2019Aspirant
Logitech Media Server on Ultra 4+ with Firmware 6.10.1
Hello, I have completed the upgrade of my Ultra 4+ from Radiator 4.2.31 to OS 6.10.1 but I am confused as to which version of Logitech Media Server (LMS) I should be installing. I was using version...
Orange_GT3
Jun 26, 2019Aspirant
OK, I worked this one out for myself. I just needed the amd64.deb file. It still doesn't show up in the OS 6 interface but LMS is there and now up and running.
- viperhansaJun 26, 2019Virtuoso
There is a version in APPS you could use...
I have not tested that since i'm not running LMS.
regards
// Hansa
- Orange_GT3Jun 26, 2019Aspirant
Thank you. I did see the NT version in the app list but I wasn't sure of its purpose since there isn't a description. I assume it has been modified to show up in the OS 6 interface.
The version that I installed, the latest from the Logitech servers, is working fine though.
- Supertramp11Jul 11, 2019Luminary
I'm using LMS on a PRO with OS 6.10.1
If you install LMS_1.0.9_all.deb after installing LMS, you will see the app in the OS 6 interface.
Everytime you want to upgrade the latest nightly, stop LMS, uninstall, install the new LMS and install the above file. Doing this since many years and works perfect.
- Orange_GT3Jul 11, 2019Aspirant
Thank you for your reply. Good to know there is a solution to displaying LMS within the OS 6.
