HenrikBM's avatar
HenrikBM
Looking for suggestions on setting up my ReadyNAS314, and choosing the right RAID setup
I've been using my ReadyNAS 314 for a long time now, with 4 x 3TB WD drives, in a RAID 5 configuration. Recently I started running out of space, so I bought a single 10TB drive to replace one of the existing 3TB drives. Needless to say I didn't read up enough before going ahead, so after I switched out the drive and let the NAS rebuild and resync, I ended up with no more space than before. I assume that this is because of the way that RAID 5 works, and I can't use the full capacity of my 10TB drive if it is surrounded by 3TB drives.
What is a good suggestion to get around this, other than replacing all my 3TB drives with 10TB drives, which would be unnecessarily expensive at this point? It seems like one option would be to try to get my NAS to treat the 10TB drive as a separate storage entity, and the 3 remaining 3TB drives as a RAIDed triad... Does that make sense, or are there other options that I can use to try to get more space out of the configuration?
Thankful for any suggestions, and please let me know if I should contribute more information - I believe the NAS is up to date with the latest drivers for its models. Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Using X-RAID you'd need two of the 3TB disks replaced with 10TB disks not just one to vertically expand your volume.
    • HenrikBM's avatar
      HenrikBM
      Thanks - I was afraid that this might be the only solution, as it is quite expensive. There is no option to have one disk be separate from the others then, with a ReadyNAS?
      • lundmilo's avatar
        lundmilo
        Luminary
        No. You can not take drives out of an active RAID array without the volume being degraded. If you have a RAID 5 with 4 drives then all data is spread out over all 4 drives so that if any drive fails the data can be restored from the remaining 3 drives.
        If you wish to go from 4 to 3 drives in your array then I'm afriad there is no other way than to backup destroy the volume and restore the data back.
  • Not only the starting point but also the history.
    For example, if your existing volume contains 2 HDDs of 2TB in RAID1. Depending on the history, you might actually be able to add a 1TB HDD in the volume!
    - If you created the volume initially with two HDDs of 1TB, then upgraded both HDDs to 2TB while being in X-RAID, there are actually two partitions of 1TB(ish) on each HDD. If you add a 1TB HDD, the volume will expand! From RAID1 (11) + RAID1 (11) to RAID5 (111) to RAID1 (11).
    - If you did the same thing but performed the upgrade of the HDDs while being in Flex-RAID, then instead of creating a secondary array, it extended the existing array in place. Therefore, you won't be able to add a 1TB HDD. From RAID1 (22) to RAID1 (22) + unused (1).
    These are based on the expansion rules of FW 6.5.0. Some things may have changed since.
    I had posted the results of a lengthy experiment here somewhere.
      • JBDragon1's avatar
        JBDragon1
        Virtuoso
        I think people are really over thinking this.  Thinking of things most people arn't going to try.   They're going to pop their drives in, when needing more space pop in larger HDD's.   How many people really are going to go backwards?  I have a bunch of smaller HDD's laying around here from over the years.  never have I thought, hey, let me throw that small drive into the NAS.  How many are using RAID 50 or 60?    As long as a person knows equal or greater size HDD as a replacment, then for the most part the Calculator works just fine.   If it's a new setup, it should also be fine.  Again for most users.   You're always going to find loopholes.  The program is at least smart enough to switch from XRaid 5 to XRaid 6 when you get to a 7th HDD.   I think in general most people are using XRaid 1, 5 or a even larger NAS, 6.
        If you're using Flex-Raid, or some off beat Raid format on your NAS, I'm pretty sure at that point you know what you're doing.  You're not some clueless person.  I'm sure there's a few exceptions to the rule.    For the most part and most people, the Raid Calculator works more then well enough.  Maybe a few things could be made more clear on the page.
  • That's the thing, people don't. And you can't expect every user to become and want to become experts in every device they have. And that's true at every level. Even if you think you know everything, maybe one day you'll meet a storage Engineer that will explain that you're not doing it the right way. Would you like if he told you that you should have researched it first? You can't know everything and be right about everything.
    Improving usability and user friendliness of a device is never a bad thing.
    The ReadyNAS UI is made to be usable even without advanced knowledge in network, storage or even computing. Adding features to help users understand what's happening or will happen surely isn't a bad thing.
    Also, reverting a bad setting on Samba or changing an option in a backup job is easy. But you can't go back once the volume started an expansion. I almost think it would be a good thing for the NAS to wait 10 minutes before using any newly inserted HDD while showing in the UI what will happen, so it gives the opportunity to the user to either change the settings or pull the HDD.
    • StephenB's avatar
      That's similar to my built-in expansion planner tool idea.  Not sure you need a 10 minute window, it'd probably be better to wait for the user to see the result and then confirm the expansion.
      Yes I agree.  Plenty of users stumble on this, and that should be enough to indicate that the UI could use some work in this area.
ProSupport for Business
