Lobnite
Sep 20, 2016Aspirant
Loss of Cloud access and 18007020001 error
Hi all I have a readynas 104 iv had it runing with no issues for a while recently i upgraded my network adding in a 1g switch and im unsure if this was the problem but after thisi lost acces to t...
Sep 20, 2016Guru - Experienced User
Can you ping the NAS from a PC?
- LobniteSep 20, 2016Aspirant
Hi
i have full access to the NAS via lan and admin page and can still see/controle the files on the drive i just cant get remote in and cloud access i can still edit and move most files the only ones i cant do anything to is the Home Folder, as as soon as i try and open the settings i get the error box up and that code.
did a ping test just to be sure and no issues on that.
- StephenBSep 20, 2016Guru - Experienced User
Ok, so the only issue is with ReadyCloud?
by the looks of it yes, im unsure of what to do to fix it at current im guessing the error code dose have something to do with that issue the Server admin page for the cloud has ready cloude of and grayed out i cant click it on or off and join is fazed out as well i can edit settings but i dont see anything in them that would help with this issue
