2Compute
Feb 25, 2019Aspirant
Malware warning
RN422
Firware 6.9.5
Antivirus feb 24, 2019 14:23:00
Nas reports:
Antivirus scanner found a threat (Doc.Malware.Sagent-6865733-0) in the file .../409_Linzensoep.doc. Please delete the infect...
Feb 25, 2019Guru - Experienced User
2Compute wrote:
Which AV-software is used by Netgear.
ClamAV.
You could report it at https://www.clamav.net/reports/fp
tamthnguyen
Feb 26, 2019Aspirant
Hi, I am getting the same virus warning to many of the word documents some of which has not been touched or modified for a few years. When I download and scan the file with AVAST antivirus, no virus was found?... Could this be a false possitive ?
Please advise .. anyone? ..
Thanks..Tam,
- StephenBFeb 26, 2019Guru - Experienced User
Likely yes, which is why I suggested reporting it to ClamAV.
