gator1350
Nov 08, 2019Aspirant
Management Dashboard for ReadyNas NVX
I had a power supply on my RN4200 and after replacing it, I cannot get to the management window. I can see the shares and mount them to the MAC, but i cannot do any administration to it. It is atached to one of the 4 ports on the back of my wifi router.
I can ping it, I can to the ip address via the web, but only to the shares screen for which it sees none.
On my MAC however, I can see it and mount my shares.
How do i get insdide this thing to do a firmware upgrade? and some other thing? Raidar does not detect it whether its on the lan or direct attached.
- JohnCM_SNETGEAR Employee Retired
Hi gator1350,
Welcome to the Community!
Can you try accessing the http://<ReadyNAS IP address>/admin, where <ReadyNAS IP address> is the IP address of the ReadyNAS, on your web browser?
You should be able to access the NAS local admin page using that URL.
- gator1350Aspirant
I have tried that with the password I gave it, a new password I assigned it, and the original admin/password, but nothing.
It keeps asking for userid and password, and the message says something about Control Panel.
Thank You,
Steve
- gator1350Aspirant
Also, I am using a Macbook Pro. I have also direct attached it to my PC and cannot connect. When I put the address in the browser, the only thing that shows up is the shares window without any shares displaying.
