bbaraniec
Aug 04, 2011Luminary
Mapping webdav as drive - Windows 7
Since always I had a Public folder available via ftp and webdav but to be honest I never used webdav. Uploading files was always a pain via webdav. Until yesterday when I found out that you can map a...
Aug 25, 2012Guru - Experienced User
Your company firewall has to be set up to forward the https port to the NAS - otherwise the connection cannot be established.
They would likely prefer you to use a VPN. Either way you will need to work with your company's IT folks.
