aruit's avatar
aruit
Guide
Jun 25, 2018
Network Map
My current setup is an Orbi Router with 3 Satellites.
Two Satellites are connectes to the Router and the third Satellite is connect to another Satellite.
The whole system is functioning OK, none of the Satellites or Router have a warning light.
In the Orbi App (2.2) this is correctly displayed, but the third Satellite does not have a green but a orange light and is also not selectable.
All the other items: INTERNET, Orbi Router and the two Orbi Satellites, which are directly connected to the Orbi Router have all a green light and are selectable.
Why is the right functioning third router an orange light?
  • Problem solved in new Orbi App 2.2.4.397
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to power reset or resync that satellite to the router? Also make sure all  units have the same version of firmware.
    DarrenM
    • aruit's avatar
      aruit
      Guide
      Yes, all units, Router and three Satellites are the same firmware version.
      I have done a power reset of this third Satellite, but with the same result.
      • DarrenM's avatar
        DarrenM
        I may need to get you in contact with support I have sent you a PM.
        DarrenM
