Gkennedy
Oct 28, 2012Aspirant
Max capacity on RNDU4000 or RNDP400U with 3TB
I'm looking at either the 4000 Ultra or Ultra Plus, diskless. The HCL says it now supports the WD Red 3TB disks. Why does the specs ofthis unit still say maximum space is 8TB? With 4 bays and all with...
Gkennedy
Oct 29, 2012Aspirant
Great, thanks for that! Should all RNDU4000's out there have the right firmware revision to support 3TB? I've found a super cheap one at a Melbourne retailer that is $399... which is about $150 cheaper than others around. Just wanted to make sure there wasn't some revision number of models that I'm not aware of that will catch me out and require hours of stuffing around trying to upgrade drive controller drivers or firmware versions?
