Webagents
Jul 25, 2011Aspirant
Maximum disk sizes
Hello, What are the maximum size disks that can be CURRENTLY be used with: Readynas NV+ Readynas Ultra 4 ...and can we expect these capacities to change in the future? Thanks
TeknoJnky
Jul 25, 2011Hero
Webagents wrote: Thanks for the reply...but why do the x86 based units only support 3TB given the explanation you posted?
3tb drives are the largest available currently.
Suffice to say, x86 devices should support any standard hard drive 3tb (or higher) with gpt support.
Since there aren't any >3tb drives, its hard to say what the future will hold.
