Webagents
Jul 25, 2011Aspirant
Maximum disk sizes
Hello, What are the maximum size disks that can be CURRENTLY be used with: Readynas NV+ Readynas Ultra 4 ...and can we expect these capacities to change in the future? Thanks
mdgm-ntgr
Jul 26, 2011NETGEAR Employee Retired
See your thread: http://www.readynas.com/forum/viewtopic.php?f=20&t=55320
The NV+ has the same CPU and memory as the Duo so it'll have pretty much the same performance. You're better off saving some more bucks and getting an Ultra imo, but if you're fine with the 2TB hard drive limit and the performance then go for it.
