ITwannabe
Apr 16, 2020Aspirant
Memory for ReadyNasPro; rndp4000
To all
I was able to upgrade the OS recently. Thank you to all. Along the way I thought memory can be updated to 2 gig. What is the max memory that can be used for ReadyNasPro; rndp4000?
Thanks again to all !!!
- bedlam1Prodigy
I have 4GB happily installed in my Pro4
- ITwannabeAspirant
To all
I updated the ram to 4 gig without problem. I looked at the OS (6.10.3) and have not found where the NAS tells me the memory size found. Not sure if the OS can address 4 gig, just curious.
If the OS can only address 2 gig then I can reduce the size of the memory stick. I did not have to buy memory since I have both size memory sticks (2 and 4 gig).
Thank you again.
PS...Look for post on APP usage. I see Plex media server and am wondering if I can use instead of ITunes to listen to music?
- bedlam1Prodigy
Install Linux-Dash from the Apps page, it will show you Memory Installed, Used and Free and a whole lot more
