Nima304
Apr 12, 2016Aspirant
Memory upgrade for ReadyNAS Pro 6
I currently have a ReadyNAS Pro Pioneer Edition with 2GBs of RAM in it. I want to upgrade to 8GBs (2x4GBs), and have looked through lots of threads of people doing this, but all the RAM modules that ...
Sandshark
Apr 12, 2016Sensei
I've gone with eBay. The latest I bought was G.Skill 2GB PC2-8500U DDR2 1066 Desktop Memory, which is CL5-5-5-15. Got 4 for $72 about a year ago. I've also used OCZ Platinum, which has similar specs. Be careful with the height of the heat spreader. Anything more than a simple wrap-around like these have will be too much. Finding 4GB modules used is a bit tougher, as most of this came out of XP machines where 4GB was the upper limit.
But I found I got a lot more bang for the buck upgrading the processor to a Intel Core 2 Duo E7500 2.93 GHz / 1066 MHz / 3M socket 775 CPU SLGTE, which now goes for under $10 on eBay. The original processor in the Pro BE or Pioneer is a Pentium Dual CPU E2160 @ 1.80GHz. Only caviat here is to make sure you have the latest motherboard BIOS (FLAME6-MB V2.0). I understand there are some very early models that are incompatible. Stock fan and heat sink keep it nice and cool (at least using Arctic Silver), as it is still has a 65W TDP.
BTW, your title says "Pro 6" and your text says "Pro Pioneer". While they are basically the same, they are not exactly. The base CPU in a Pro 6 is a Pentium Dual-Core E5300 @ 2.60GHz. Not enough extra bang to bother upgrading that to the Core2 above unless you need virtulalization (VT-x). BTW, in OS 4.2.x, CPU and motherboard BIOS info are in dmesg.log. In 6.x, it's not nearly as informative.
Apr 13, 2016Guru - Experienced User
FWIW, the reason for my memory uplift was that Crashplan was running out (so backups were failing).
