pkal
May 15, 2017Tutor
Memory upgrade for Readynas RN 422
Output from "top" command: top - 20:04:50 up 6 days, 1:46, 1 user, load average: 0.04, 0.06, 0.00 Tasks: 173 total, 1 running, 172 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.5 us, 0.5 sy, 0.0 ...
- May 16, 2017
I'm informed by hardware engineering that on the RN422 and RN424 the RAM is soldered on and so it cannot be replaced.
mdgm-ntgr
May 15, 2017NETGEAR Employee Retired
dmidecode suggests the RN422 and RN424 both have 4 DIMM slots (I guess not all of those would be usable though due to space constraints) and that a 2GB DDR4 Micron Synchronous Unbuffered (Unregistered) module with speed 1866 Mhz is installed
I don't know for sure what's in the unit but will try to find out. dmidecode suggests it supports a maximum of 32GB per slot (but again that would need some confirmation).
Which services are you running on your NAS? Are you running any apps?
Welcome to the community!
- mdgm-ntgrMay 16, 2017NETGEAR Employee Retired
