pkal
May 15, 2017Tutor
Memory upgrade for Readynas RN 422
Output from "top" command: top - 20:04:50 up 6 days, 1:46, 1 user, load average: 0.04, 0.06, 0.00 Tasks: 173 total, 1 running, 172 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.5 us, 0.5 sy, 0.0 ...
- May 16, 2017
I'm informed by hardware engineering that on the RN422 and RN424 the RAM is soldered on and so it cannot be replaced.
mdgm-ntgr
May 17, 2017NETGEAR Employee Retired
If you want to be able to replace RAM (at your own risk, not supported) we do have the 520 series and 620 series:
RN524X: 2 memory slots (max: 32GB), support up to DDR4-1866
RN526X/RN528X: 4 memory slots (Max: 64GB), support up to DDR4-1866
RN626X/RN628X: 4 memory slots (Max: 64GB), support up to DDR4-2133
We use DDR4 UDIMM ECC memory module on shipping.
pkal
May 19, 2017Tutor
The following is the sequence of events:
1. I asked Netgear pres-sales support asking whether the RN422 memory could be upgraded - since Resilio-Sync warned me that the 2GB of RAM might be insufficient.
2. I was assured by Netgear that the memory on this device CAN BE UPGRADED.
3. I bought the device from Amazon (following a link on Netgear's web-site).
4. One week later, I asked Netgear for the RAM memory specification.
5. After 2 weeks of dithering - Netgear informed me that the memory on the unit cannot be upgraded.
At THIS point - I asked Netgear whether they would be willing to accept a return for the unit - since they had given me incorrect information on pre-sales support. The comment you sent - was in response to this question.
This is clearly a case of pre-sales telling me one thing and then customer-support saying something quite the opposite after the unit had been bought. I believe there is a technical term for it???
Please (a) let me know whether Netgear is willing to upgrade the memory under technical support (I do NOT want to void the warranty), or (b) whether Netgear is willing me offer me another model (equivalent or better) whose memory CAN be upgraded.
I remain open to a CONSTRUCTIVE and POSITIVE disucssion.
Pramod
- mdgm-ntgrMay 19, 2017NETGEAR Employee Retired
I can see that unfortunately incorrect Pre Sales advice was given looking at your case notes. I've asked customer service to reach out to you.
The memory (RAM) on the unit can't be upgraded. It's soldered on. I asked hardware engineering and this is what they told me. They're the ones that designed the hardware. They are the ones that can give a definitive answer on things like whether memory upgrades are possible even though they're not supported.
- mdgm-ntgrMay 23, 2017NETGEAR Employee Retired
The RN426 and RN428 were just announced today. These use memory slots. It can support both UDIMM ECC or UDIMM non-ECC (however you should stick to UDIMM ECC RAM). Max memory capacity is 64GB with 4 memory modules. The current speed we ship is 2133MHz. Replacing the memory is not supported, but can be done on the RN426 and RN428.
