Biker1
Dec 03, 2006Tutor
Memory upgrade of a ReadyNAS NV+
Biker wants to share some of his own experience from a memory upgrade of his ReadyNAS NV+. He could'nt find this documented anywhere.
First some tips:
A simple HowTo:
As Biker already told you, be careful! Biker won't accept any responsibility of you foul up.
First some tips:
There is only one slot for the memory stick. The original memory stick, as delivered from Infrant, will become redundant. And most likely take up place in one of your drawers for ever.
Don't buy a 512MB stick, thinking that you'll add another 512MB later. Won't work. If you aim for 1GB of memory, get it right away.
Almost anyone that can handle a Phillips screwdriver will be able to do the upgrade.
A simple HowTo:
Shutdown the NV+ and power it off.
Disconnect all cables.
Remove the four phillips screws on the back side. They will release the two side panels.
Pull the side panels to rear of the unit, about 1/4" or some 6-7 millimeters.
Carefully remove the side panels.
Remove the four phillips screws holding the top panel and remove the panel.
You will find the existing memory stick under the top panel.
Carefully bend the two plastic arms on the short sides of the memory stick to the sides. Don't brake them! Help the existing stick to pop up. Don't try to pull the stick backwards. It will pop up to almost 45 degrees. Once in the 45 degrees position, you can pull the stick out. It requires a very small amount of force to convince the stick to come out. Be careful.
Store away the old stick in your drawer for ever.
Push the new stick in the slot, respecting the angle. Make sure it seats correctly. There is a tab betwen the contacts making it impossible to install it upside-down. Once correctly seated, carefully push it down until the two plastic arms grab the stick. You may need to help the plastic arms to fully get in place.
Remount the top panel and the two side panels. Reconnect your cables and power on.
Verify the new memory amount in FrontView.
- JonavinAspirantHow long is the memory test supposed to take?
- JonavinAspirantLooks like it took just over an hour for the first full pass (8 cycles). Doing a couple more because bad RAM can cause a lot of random problems so you can never be too safe.
- homieAspiranthow can I see how much memory my ReadyNas NV+ has (besides opening it up)
- mdgm-ntgrNETGEAR Employee RetiredLook at the home page of Frontview (the web admin interface).
- BFGAspirantNot sure if this is the right place for help. [edit: solved]
READYNAS NV+ 2 TB RND4450 Running 4.1.7
Trying a ram upgrade to 1gb. Crucial memory on the HCL. Installed, powered on holding the button for the memory test, saw no flashing beyond the initial flicker.
Then lights 1 and 3 lit solid, and nothing further. Let go after about 30 seconds, lights remain lit, no other activity and now can't switch off. Power button not responding.
Edit: Well, I had to pull the power cord. On next power-on, I was able to do the mem test and all was fine. - HitokiriAspirantHow do I do the memory test? The link to the wiki page was not found :(
I upgraded my Duo from 256megs to 1024 and it runs like it always have apart from now saying it has 1024 megs. - mdgm-ntgrNETGEAR Employee RetiredThis is an old thread. The memory test instructions are here: http://www.readynas.com/forum/faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F
Be sure to run the memory test at least twice.
Be aware that NetGear doesn't support 3rd party memory upgrades. So if you encounter problems due to using 3rd party memory NetGear may be unable to help. See http://www.readynas.com/?page_id=83 - HitokiriAspirantThanks for the link i'll be doing the memory test right away.
- smartstartAspirantmemory test instructions are very much of use! good job done, guys
