dsnpevl
Feb 02, 2019Virtuoso
Message fields in some mails from "NETGEAR community <community@netgear.com>" are not filled in
Accasionally I receive notification mails from this Netgear Community. There seems to be a problem with the messages with the title "Did you get the answer you needed?". The variable fields ($.....) ...
Feb 02, 2019Guru - Experienced User
I get these from time to time myself. Hopefully they will track it down and fix it.
- dsnpevlFeb 10, 2019Virtuoso
Well, to illustrate the problem, here's the flawwed mail that I get based on StephenB 's reply. Eventhough I haven't accepted this as a solution, the system seems to want to automatically accept this reply as a solution after 7 or 8 days? And the variables are still not filled in.
