lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?...
PapaBear1
Aug 19, 2012Apprentice
What type of socket does it have. I finally managed to find specs and it says for management it has USB and RS-232. It just does not tell which USB socket it has, square or flat. Flat is normally for the host (the ones on the ReadyNAS) and the square is normally for the attached device (as found on hard drives, etc). If it is the square socket then a standard USB cable should work, if the flat then you need a USB cable with two flat connectors.
