lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?...
Aug 19, 2012Guru - Experienced User
You can see a picture here: http://www.fusionps.com.au/products/ups ... e_Max.html
PapaBear wrote: What type of socket does it have. I finally managed to find specs and it says for management it has USB and RS-232. It just does not tell which USB socket it has, square or flat. Flat is normally for the host (the ones on the ReadyNAS) and the square is normally for the attached device (as found on hard drives, etc). If it is the square socket then a standard USB cable should work, if the flat then you need a USB cable with two flat connectors.
It appears to filter a single ethernet connection (the top two connectors on the right), and also have an additional RJ45 connector for the control port. I believe there are two custom cables available for the control port, one which adapts it to RS-232, the other adapts it to USB. Some APC UPS also do it this way. You can find a cable here: http://www.thenerds.net/STARTECHCOM.Sta ... ml#details - though I don't know for sure if that will work with the Ellipse, or just the APC.
