lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?...
claykin
Aug 22, 2012Aspirant
StephenB wrote: Some APC apparently use RJ45 also (http://www.apc.com/resource/include/tec ... sku=AP9827).
APC AP9827 is a RJ50 cable. Two additional pins so RJ45 won't work. I have used many APC UPS over the years and I am unfamiliar with a APC signaling cable using RJ45. They either use serial, the now outdated/discontinued RJ50 AP9827, or a conventional A/B USB cable.
Your Eaton unit seems to use a unique cable. The spec sheet claims its a combined USB/serial cable. I would call them and ask for a cable. FYI, if you were a previous fan of MGE single phase UPS (under 10kva), MGE was owned by Schneider Electric up until 2007. Schneider bought APC in 2007 and at the same time sold off MGE single phase products to Eaton. At least in the US, Eaton has done a fairly crap job promoting their consumer/SMB products. They are typically difficult to find and the one time I called their support, I knew the old company was history.
