lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?...
Aug 22, 2012Guru - Experienced User
Agreed, the reference to RJ45 in the spec above is apparently an error. As posted above, you can find a couple of posts on the Ellipse 600 cable. Apparently Eaton is not responsive.
claykin wrote:
StephenB wrote: Some APC apparently use RJ45 also (http://www.apc.com/resource/include/tec ... sku=AP9827).
APC AP9827 is a RJ50 cable.
Lucifor, please post your results with your hand-built cable.
