lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?...
claykin
Aug 23, 2012Aspirant
@PapaBear - APC began transitioning their consumer Backups to a standard A/B USB cable back in Q3 2011. Its been slow going, but recently I notice many models are now using standard USB type A/B cable.
Check the manufactured date code on the BR1500G you just bought. To do this check the S/N and read digits 3-6. For example if they are 1132 then your unit was manufactured the 32 week of 2011. I will never buy one that is over 6 months because the batteries are decaying and beginning to sulfate.
