putzdan
Aug 04, 2021Star
Migrating data from Readynas Ultra 2 from RAIDar 4.2.31 to 6.9.5
Starting: I've got an amazing NAS from Netgear, being able to scale up since many years: 2x4 TB in RAID 1 (mirroring) with 2 GB of RAM. Firmware 4.2.31. It is powerfull, just what I needed. Due t...
- Aug 04, 2021
putzdan wrote:
I have now restarted the NAS as you asked for it. It went to the same status: Power button is blinking blue and activity LED is blinking from time to time.
Raidar are showing the same status as mentioned: "Management Service is offline".
thx
See if the RAIDar function to download logs is successful.
You could try another factory default from the boot menu.
Aug 04, 2021Guru - Experienced User
It should be finished by now, so I suggest powering down the NAS and restarting it.
putzdan wrote:
with 2 GB of RAM.
Did you upgrade this? Stock RAM in 4.2.x systems was 1 GB.
putzdan
Aug 04, 2021Star
Hi StephenB,
Yes, I did upgrade the RAM from 1 to 2 GB two years ago when I upgraded from 2x 2TB to 2x 4TB.
thx
- StephenBAug 04, 2021Guru - Experienced User
thx
- putzdanAug 04, 2021Star
I switched off twice my NAS.
I tried to proceed a manuall "factory default".
After few minutes, I could follow the starting steps of the NAS.
Everything is now on green. I will wait for the sync process to be finalize.
Restart the NAS properly and try an update of the new OS system.
BTW. Even with my other Netgear NAS 424, I am not able to set the gmail smtp server and I also could not find any detailed description how to proceed. Maybe Netgear is aware about this recurring issue?
