bradjj
Oct 15, 2017Aspirant
Mimic Dropbox Service on RN102 and Linux
I have been using Dropbox to sync files across multiple Linux machines at home. While this works well I would like to keep my own data on my ReadyNAS rather than someone else's cloud. I can moun...
Sandshark
Oct 15, 2017Sensei
What error message, if any, are you getting? Have you verified SMB access is on for the system and share? Does the mount point directory exist? Make sure your mount point in the command has the full path starting from /.
I have done this with two ReadyNASes, but used NFS instead of SMB for better retention of ownership and privileges. Once I had it working with a manual mount command, I added a line to /etc/fstab to have it auto-mounted at boot.
bradjj
Oct 16, 2017Aspirant
Error message: For more details see mount(8).
SMB is green when I go to the admin page for the NAS at, system>settings NFS is also green.
Below is the output and command:
bradley@WR250:~$ sudo mount [-t smb -o username=bradley,password=xxxxxxxx] //http://192.168.1.2/2TB /home/bradley
[sudo] password for bradley:
Usage:
mount [-lhV]
mount -a [options]
mount [options] [--source] <source> | [--target] <directory>
mount [options] <source> <directory>
mount <operation> <mountpoint> [<target>]
Mount a filesystem.
Options:
-a, --all mount all filesystems mentioned in fstab
-c, --no-canonicalize don't canonicalise paths
-f, --fake dry run; skip the mount(2) syscall
-F, --fork fork off for each device (use with -a)
-T, --fstab <path> alternative file to /etc/fstab
-i, --internal-only don't call the mount.<type> helpers
-l, --show-labels show also filesystem labels
-n, --no-mtab don't write to /etc/mtab
-o, --options <list> comma-separated list of mount options
-O, --test-opts <list> limit the set of filesystems (use with -a)
-r, --read-only mount the filesystem read-only (same as -o ro)
-t, --types <list> limit the set of filesystem types
--source <src> explicitly specifies source (path, label, uuid)
--target <target> explicitly specifies mountpoint
-v, --verbose say what is being done
-w, --rw, --read-write mount the filesystem read-write (default)
-h, --help display this help and exit
-V, --version output version information and exit
Source:
-L, --label <label> synonym for LABEL=<label>
-U, --uuid <uuid> synonym for UUID=<uuid>
LABEL=<label> specifies device by filesystem label
UUID=<uuid> specifies device by filesystem UUID
PARTLABEL=<label> specifies device by partition label
PARTUUID=<uuid> specifies device by partition UUID
<device> specifies device by path
<directory> mountpoint for bind mounts (see --bind/rbind)
<file> regular file for loopdev setup
Operations:
-B, --bind mount a subtree somewhere else (same as -o bind)
-M, --move move a subtree to some other place
-R, --rbind mount a subtree and all submounts somewhere else
--make-shared mark a subtree as shared
--make-slave mark a subtree as slave
--make-private mark a subtree as private
--make-unbindable mark a subtree as unbindable
--make-rshared recursively mark a whole subtree as shared
--make-rslave recursively mark a whole subtree as slave
--make-rprivate recursively mark a whole subtree as private
--make-runbindable recursively mark a whole subtree as unbindable
bradley@WR250:~$
