mxh
Nov 18, 2018Aspirant
Mix Raid setup in one NAS
I have two ReadyNAS devices (NX+ and 314)
Both are currently set up with 2 hard drives in a RAID 0 config and hold 'transient' files (hence no need for redundancy)
I would also like to st...
- Nov 19, 2018
Hi mxh
Welcome to the Community!
You have NVX or NV+? You can do that setup by setting your NAS to Flex-RAID, this way it will allow you to setup more than one volume. However with OS4 you might need to perform a Factory reset in order to change to Flex-RAID. Please see RAIDiator 4.1 manual but with OS 6 you will just have to switch from X-RAID to Flex-RAID by ticking a button. Please see OS 6 manual.
Once on Flex-RAID you will be able to create a new volume for the additional two disks you will add. See OS 6 Manual on page 30 and RAIDiator 4.1 Manual page 20.
Hope this helps!
Regards
Marc_V
Nov 19, 2018NETGEAR Employee Retired
Hi mxh
Hope this helps!
Regards
- StephenBNov 19, 2018Guru - Experienced User
If you are already running RAID-0 with two disks, the systems are already running Flex-RAID.
Generally I don't recommend RAID-0 volumes that span multiple disks, as they are very fragile - when either disk fails you lose all the data on both drives. If you do a factory reset for some reason, you might consider splitting that volume into two (one per disk).
- mxhNov 19, 2018Aspirant
Sorry, it's NV+ - and with firmware 4.1.16 so assume that's OS4?
I expected it to be a bit of a pain to do, but it urned out to be very straightforward - deleted all volumes and added the extra disks in. Then created the RAID 0 drive, rebooted and created the RAID 1 drive.
Thanks for your help :)
